This page was generated from jupyter-files/unit-5.0-mpi_basics/MPI-Parallelization in NGSolve.ipynb.
5.0 MPI-Parallelization with NGSolve¶
How do we start a distributed computation
mpirun/mpiexec
batch systems
jupyter-magic
Basics of MPI-parallel NGSolve
distrubuted meshes
distributed Finite Element Spaces
distributed Linear Algebra
solvers & preconditioners
Within an MPI job, each process in a computation is given a “rank”, a numer from \(0\ldots n_p\), which is used as it’s identifier.
Directly - mpiexec¶
Jupyter-Magic¶
connectme.py usrmtg_user_data
Download those and call
How to use it¶
num_procs = '5'
start_cluster(num_procs)
connect_cluster()
%%px --targets 3:5
stop_cluster()
Batch System¶
** sbatch slurm_file **
The Rest of the talk:¶
Basics: Distributed Meshes, Finite Element Spcaces and Lienar Algebra
FETI-DP I: Point Constraints in 2d
FETI-DP II: Point Constraints in 3d
FETI-DP III: Point- and Edgeconstraints
FETI-DP IV: Inexact FETI-DP
